소개
Before replacing the battery, be sure that the battery is not simply without a charge. Plug the phone into an outlet or a computer through a USB connection and see if the phone begins to charge. You won't need any special tools to replace the battery.
The first step is to remove the back cover off of the phone. To do this, place both your thumbs on the two top corners of the device and simply pop it off.
다른 15명이 해당 안내서를 완성하였습니다.
