주요 콘텐츠로 건너뛰기
Nokia X Display Assembly Replacement
필요한 것
  1. Nokia X Display Assembly Replacement, Battery: 1 단계, 이미지 1/1
    • The first step is to remove the back cover off of the phone. To do this, place both your thumbs on the two top corners of the device and simply pop it off.
  2. Nokia X Display Assembly Replacement: 2 단계, 이미지 1/1
    • To remove the battery, simply use your finger to pry the battery out of its slot.
  3. Nokia X Display Assembly Replacement: 3 단계, 이미지 1/1
    • Inserting a new battery is as simple as lining up the gold connectors and sliding the battery in text-side down.
  4. Nokia X Display Assembly Replacement, Display Assembly: 4 단계, 이미지 1/2 Nokia X Display Assembly Replacement, Display Assembly: 4 단계, 이미지 2/2
    • Remove the four 5.33mm T5 Torx screws which are located in the corners of the phone.
    • Remove the seven 4.00mm T5 Torx screws that line the phone between the corners.
  5. Nokia X Display Assembly Replacement: 5 단계, 이미지 1/2 Nokia X Display Assembly Replacement: 5 단계, 이미지 2/2
    • To remove the screen from the motherboard, you will need to apply some force until you feel it snap off. If the connectors unhook themselves, don't worry.
  6. Nokia X Display Assembly Replacement: 6 단계, 이미지 1/1
    • If the connectors are still attached, simply unhook them by lifting the top of the connector with your finger.
결론
다른 29명이 해당 안내서를 완성하였습니다.
Avery Dorsey
회원 가입일: 01/21/15
1,894 평판
안내서 4개 작성하였습니다
USF Tampa, Team 6-1, Brown Winter 2015 USF Tampa, Team 6-1, Brown Winter 2015 회원
USFT-BROWN-W15S6G1
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 22
전체 시간: 5,699
