주요 콘텐츠로 건너뛰기
Nokia X USB Port Replacement
필요한 것
  1. Nokia X USB Port Replacement, Nokia X Disassembly Prerequisites: 1 단계, 이미지 1/1
    • Remove the back cover of the device by applying light pressure toward the outer rim and display.
  2. Nokia X USB Port Replacement: 2 단계, 이미지 1/1
    • Remove 7 (size 4 M1 4*3.5) and 4(size 6 M2 6*4.5) screws using P5 hex screwdriver.
    • The M2 screws are shown in red.
    • The M1 screws are shown in orange.
  3. Nokia X USB Port Replacement: 3 단계, 이미지 1/1
    • Gently separate the display from the chassis.
    • Slowly spread the display and chassis until the inside of the device is reachable.
    • Do not pull apart.
  4. Nokia X USB Port Replacement: 4 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Spudger
    $2.99
    구매
    • Using the spudger tool, release the top flex ribbon from the light swap package.
  5. Nokia X USB Port Replacement, USB Port: 5 단계, 이미지 1/2 Nokia X USB Port Replacement, USB Port: 5 단계, 이미지 2/2
    • Again, using a spudger tool, release the rear facing camera from the light swap display.
    • Carefully remove the light swap display from the chassis by applying pressure to the circuit board.
  6. Nokia X USB Port Replacement: 6 단계, 이미지 1/1
    • Using a soldering iron, desolder they broken USB port.
    • Solder your replacement USB port onto the light swap package.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Josh Perino
회원 가입일: 03/04/17
436 평판
안내서 2개 작성하였습니다
IUPUI, Team S7-G7, Wilson Spring 2017 IUPUI, Team S7-G7, Wilson Spring 2017 회원
IUPUI-WILSON-S17S7G7
3 회원들
안내서 8개 작성하였습니다
댓글 한 개
my mobile usb port no pls replacement
Giri GOWDA Nature RIDER - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 9
전체 시간: 1,352
