소개
Is your Nokia X unable to connect to a USB charger? This guide will shows how to replace a faulty USB port.
필요한 것
Remove the back cover of the device by applying light pressure toward the outer rim and display.
Again, using a spudger tool, release the rear facing camera from the light swap display.
Carefully remove the light swap display from the chassis by applying pressure to the circuit board.
다른 6명이 해당 안내서를 완성하였습니다.
