주요 콘텐츠로 건너뛰기
Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement
필요한 것
  1. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Back Cover Removal: 1 단계, 이미지 1/1
    • You will first need to separate the back cover from the device.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
  2. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Battery Removal: 2 단계, 이미지 1/2 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Battery Removal: 2 단계, 이미지 2/2
    • Remove the back cover.
    • Use a plastic opening tool to lift the battery. Then, remove it.
  3. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Screen Separation part 1: 3 단계, 이미지 1/2 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Screen Separation part 1: 3 단계, 이미지 2/2
    • To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
    • You will need a T5 Precision Torx screw driver to remove the screws.
    • The locations of the T5x3.4mm screws are indicated in the picture.
    • The locations of the T5x4.1mm screws are indicated in the picture.
  4. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Screen Separation part 2: 4 단계, 이미지 1/3 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Screen Separation part 2: 4 단계, 이미지 2/3 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Screen Separation part 2: 4 단계, 이미지 3/3
    • Use the plastic opening tool to gently pry the device apart.
    • There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
    • Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
  5. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, System components: 5 단계, 이미지 1/1
    • Once the device is open, take note of all the components.
  6. Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Remove motherboard connectors: 6 단계, 이미지 1/3 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Remove motherboard connectors: 6 단계, 이미지 2/3 Nokia XL Dual SIM Touch Screen, Volume Buttons, and Power/Screen Lock button Replacement, Remove motherboard connectors: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Gently unsnap the 3 motherboard connectors for the touch screen assembly with tweezers.
    • The touch screen, volume buttons, and power/screen lock button assembly can now be removed.
결론
다른 16명이 해당 안내서를 완성하였습니다.
Christopher Weaver
회원 가입일: 09/25/14
984 평판
안내서 2개 작성하였습니다
USF Tampa, Team 1-4, Brown Fall 2014 USF Tampa, Team 1-4, Brown Fall 2014 회원
USFT-BROWN-F14S1G4
3 회원들
안내서 7개 작성하였습니다
댓글 한 개
next pic i whant this information touch change....
prakash prakash - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 16,056
