소개
Use this guide to bring your Nokia XL Dual Sim back from the dead with a new battery.
필요한 것
Shut off the device completely.
Separate the back cover from the device by gently prying the opening out at the loose locations.
Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar item.
Once the back cover is removed, the battery will be in plain sight.
Again, use the plastic opening tool to lift the battery. From there, you can simply remove it.
다른 2명이 해당 안내서를 완성하였습니다.
