주요 콘텐츠로 건너뛰기
Nokia XL Dual Sim Rear Camera Replacement
필요한 것
  1. Nokia XL Dual Sim Rear Camera Replacement, Back Cover Removal: 1 단계, 이미지 1개 중 1개
    • You will first need to separate the back cover from the device.
    • Gently pry open each side of the device at the indicated locations. It is best to use a plastic opening tool or similar tool.
  2. Nokia XL Dual Sim Rear Camera Replacement, Battery Removal: 2 단계, 이미지 2개 중 1개 Nokia XL Dual Sim Rear Camera Replacement, Battery Removal: 2 단계, 이미지 2개 중 2개
    • Remove the back cover.
    • Use a plastic opening tool to lift the battery. Then, remove it.
  3. Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 1: 3 단계, 이미지 2개 중 1개 Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 1: 3 단계, 이미지 2개 중 2개
    • To access the inner components of the device, remove the various screws. Keep them separate, and organize them by size.
    • You will need a T5 Precision Torx screw driver to remove the screws.
    • The locations of the T5x3.4mm screws are indicated in the picture.
    • The locations of the T5x4.1mm screws are indicated in the picture.
  4. Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 2: 4 단계, 이미지 3개 중 1개 Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 2: 4 단계, 이미지 3개 중 2개 Nokia XL Dual Sim Rear Camera Replacement, Screen Separation part 2: 4 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to gently pry the device apart.
    • There are flaps on both sides of the phone as indicated in the picture. This is what you will need to pry apart.
    • Please be cautious when opening the device. There are various connectors inside the device that must be handled with care.
  5. Nokia XL Dual Sim Rear Camera Replacement, System components: 5 단계, 이미지 1개 중 1개
    • Once the device is open, take note of all the components.
  6. Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 1: 6 단계, 이미지 2개 중 1개 Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 1: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • With tweezers, gently release the rear camera motherboard connector.
  7. Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 2: 7 단계, 이미지 3개 중 1개 Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 2: 7 단계, 이미지 3개 중 2개 Nokia XL Dual Sim Rear Camera Replacement, Camera Removal Pt. 2: 7 단계, 이미지 3개 중 3개
    • Gently pull the motherboard connector upward to remove the rear camera component.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Shadeed Bilal
회원 가입일: 09/25/14
231 평판
안내서 4개를 작성함
USF Tampa, Team 1-4, Brown Fall 2014 USF Tampa, Team 1-4, Brown Fall 2014 회원
USFT-BROWN-F14S1G4
3 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 9
전체 시간: 892
