필요한 것
Remove the two 3.8 mm screws located in the back right corner of the device using the T5 Torx screwdriver.
Remove the ten 4.0 mm screws from the device's perimeter using the T5 Torx screwdriver.
Gently lift and peel the orange and grey ribbon connectors to disconnect the screen and motherboard.
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
