주요 콘텐츠로 건너뛰기
Nook HD+ Antenna Replacement
필요한 것
  1. Nook HD+ Antenna Replacement, Antenna: 1 단계, 이미지 1/1
    • Pry the front frame off of the nook by wedging the plastic opening piece between the frame and the nook.
  2. Nook HD+ Antenna Replacement, Remove the screws: 2 단계, 이미지 1/2 Nook HD+ Antenna Replacement, Remove the screws: 2 단계, 이미지 2/2
    • Remove every visible screw from the front of the nook using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
  3. Nook HD+ Antenna Replacement, Remove the chassis: 3 단계, 이미지 1/2 Nook HD+ Antenna Replacement, Remove the chassis: 3 단계, 이미지 2/2
    • Carefully remove the center chassis from the bottom frame.
  4. Nook HD+ Antenna Replacement, Dettatch battery: 4 단계, 이미지 1/3 Nook HD+ Antenna Replacement, Dettatch battery: 4 단계, 이미지 2/3 Nook HD+ Antenna Replacement, Dettatch battery: 4 단계, 이미지 3/3
    • Detach the battery ribbon from the motherboard.
  5. Nook HD+ Antenna Replacement, Flip the center chassis: 5 단계, 이미지 1/1
    • Flip the center chassis so that the screen is facing down, and the hole is positioned in the bottom right corner.
  6. Nook HD+ Antenna Replacement, Remove the antenna part 1: 6 단계, 이미지 1/2 Nook HD+ Antenna Replacement, Remove the antenna part 1: 6 단계, 이미지 2/2
    • Remove the wire from the attachment on the motherboard (this wire un-clips).
  7. Nook HD+ Antenna Replacement, Remove the antenna part 2: 7 단계, 이미지 1/2 Nook HD+ Antenna Replacement, Remove the antenna part 2: 7 단계, 이미지 2/2
    • Apply soldering iron to the wire where it connects on the frame side. Remove wire when the solder is molten.
  8. Nook HD+ Antenna Replacement, Place new antenna.: 8 단계, 이미지 1/2 Nook HD+ Antenna Replacement, Place new antenna.: 8 단계, 이미지 2/2
    • Replace new antenna following all the steps in reverse.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Elijah Gonsalves
회원 가입일: 10/24/14
1,049 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 2-3, Duarte Fall 2014 UMass Dartmouth, Team 2-3, Duarte Fall 2014 회원
UMASSD-DUARTE-F14S2G3
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,106
