주요 콘텐츠로 건너뛰기
Nook HD+ Battery Replacement
필요한 것
  1. Nook HD+ Battery Replacement, Remove the front frame: 1 단계, 이미지 1/3 Nook HD+ Battery Replacement, Remove the front frame: 1 단계, 이미지 2/3 Nook HD+ Battery Replacement, Remove the front frame: 1 단계, 이미지 3/3
    • Wedge the plastic opening piece underneath the bottom left hand corner of the front frame. Pry the frame off of the Nook.
  2. Nook HD+ Battery Replacement, Remove the screws: 2 단계, 이미지 1/2 Nook HD+ Battery Replacement, Remove the screws: 2 단계, 이미지 2/2
    • Remove every visible screw tying the chassis to the bottom frame using the T-4 attachment for the screwdriver in the iFixit screwdriver kit.
  3. Nook HD+ Battery Replacement, Remove the chassis: 3 단계, 이미지 1/1
    • Carefully remove center chassis from bottom frame.
  4. Nook HD+ Battery Replacement, Detach battery: 4 단계, 이미지 1/3 Nook HD+ Battery Replacement, Detach battery: 4 단계, 이미지 2/3 Nook HD+ Battery Replacement, Detach battery: 4 단계, 이미지 3/3
    • Detach the battery ribbon from the motherboard.
  5. Nook HD+ Battery Replacement, Remove the battery: 5 단계, 이미지 1/2 Nook HD+ Battery Replacement, Remove the battery: 5 단계, 이미지 2/2
    • Pry battery off of bottom frame using plastic opening tool.
  6. Nook HD+ Battery Replacement, Place new battery: 6 단계, 이미지 1/1
    • Apply glue to the bottom side of new battery. Re-insert new battery onto bottom frame and allow to dry. Follow steps in reverse to put nook back together.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Elijah Gonsalves
회원 가입일: 10/24/14
1,049 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 2-3, Duarte Fall 2014 UMass Dartmouth, Team 2-3, Duarte Fall 2014 회원
UMASSD-DUARTE-F14S2G3
5 회원들
안내서 10개 작성하였습니다
댓글 5개
Does model affect battery type? The replacement battery was stated so I'm just curious
Jon - 답글
Where i can buy new battery, or any similar [6000 mAh] ?
Sebastian kukosh - 답글
Anyone have a lead on good batteries?
omarhani - 답글
clear directions, liked this guide
wandat100 - 답글
i have a Barnes and noble nook HD+ and how it won't charger at all.
Tina Brown - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 13
30일 전: 46
전체 시간: 9,504
