주요 콘텐츠로 건너뛰기
Nook HD+ Motherboard Replacement
필요한 것
  1. Nook HD+ Motherboard Replacement, Motherboard: 1 단계, 이미지 1/3 Nook HD+ Motherboard Replacement, Motherboard: 1 단계, 이미지 2/3 Nook HD+ Motherboard Replacement, Motherboard: 1 단계, 이미지 3/3
    • Open the plastic frame by wedging the plastic iFixit opening tool under the plastic frame to remove adhesive.
    • Pop up all plastic tabs that secure the frame to the chassis.
  2. Nook HD+ Motherboard Replacement: 2 단계, 이미지 1/3 Nook HD+ Motherboard Replacement: 2 단계, 이미지 2/3 Nook HD+ Motherboard Replacement: 2 단계, 이미지 3/3
    • Remove twenty 5.0 mm Torx T5 screws that hold the chassis to the back casing using a screwdriver.
    • Disconnect battery from motherboard.
    • Remove back casing.
  3. Nook HD+ Motherboard Replacement: 3 단계, 이미지 1/2 Nook HD+ Motherboard Replacement: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Disconnect both ribbons from the motherboard by pulling up on the dark grey flaps and pulling out the ribbons.
    • Use tweezers to lift the flaps.
  4. Nook HD+ Motherboard Replacement: 4 단계, 이미지 1/1
    • Disconnect the small red and black ribbon connected to the speaker from the white clip on the motherboard.
    • No tool is needed. Gently pull on the wires until the piece disconnects.
  5. Nook HD+ Motherboard Replacement: 5 단계, 이미지 1/1
    • Disconnect antenna from motherboard by pulling up with slight force.
  6. Nook HD+ Motherboard Replacement: 6 단계, 이미지 1/2 Nook HD+ Motherboard Replacement: 6 단계, 이미지 2/2
    • Remove two 5.0 mm Torx T5 screws attached to the motherboard using a screwdriver.
    • Lift the small foam piece attached to the black strip on the motherboard and gently pull up.
  7. Nook HD+ Motherboard Replacement: 7 단계, 이미지 1/2 Nook HD+ Motherboard Replacement: 7 단계, 이미지 2/2
    • With the black strip lifted, carefully snap the motherboard out of the plastic pieces holding it down.
    • Remove the motherboard.
결론
Brennan Holcombe
회원 가입일: 03/31/22
256 평판
안내서 2개 작성하였습니다
IUPUI, Team 3-3, Harley Spring 2022 IUPUI, Team 3-3, Harley Spring 2022 회원
IUPUI-HARLEY-S22S3G3
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 5
전체 시간: 255
