주요 콘텐츠로 건너뛰기
Nook HD+ Speaker Replacement
필요한 것
  1. Nook HD+ Speaker Replacement, Take off the Top Frame: 1 단계, 이미지 1/1
    • Wedge the plastic opening piece underneath the bottom left hand corner of the front frame
    • Pry open the front frame.
  2. Nook HD+ Speaker Replacement, Remove the screws: 2 단계, 이미지 1/2 Nook HD+ Speaker Replacement, Remove the screws: 2 단계, 이미지 2/2
    • Remove every visible screw tying the chassis to the bottom frame using a T-4 screwdriver bit.
  3. Nook HD+ Speaker Replacement, Remove the Battery: 3 단계, 이미지 1/2 Nook HD+ Speaker Replacement, Remove the Battery: 3 단계, 이미지 2/2
    • Carefully remove the bottom frame from center chassis.
    • Detach the battery ribbon from the motherboard.
    • Flip the center chaise onto the screen side with the hole positioned on the bottom right hand corner.
  4. Nook HD+ Speaker Replacement, Unscrew the speaker: 4 단계, 이미지 1/1
    • In the bottom left hand corner remove the 3 screws that at attached to the speaker
    • Disconnect the small red and black ribbon connected to the speaker from the white clip on the mother board.
    • Replace old speaker with new speaker then follow instructions in reverse order to reassemble
결론
다른 2명이 해당 안내서를 완성하였습니다.
Alex Pelicas
회원 가입일: 10/17/14
283 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 2-3, Duarte Fall 2014 UMass Dartmouth, Team 2-3, Duarte Fall 2014 회원
UMASSD-DUARTE-F14S2G3
5 회원들
안내서 10개 작성하였습니다
댓글 한 개
After purchasing a replacement speaker, these steps worked well. Process to a fairly relaxed 20 minutes.
The only thing I’d add is that the speaker is part # AAC121217U22A, and appears to be a bespoke part containing two speakers.
Knowing what part to look for may help others looking for a replacement part.
Jamal Taylor - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 752
