주요 콘텐츠로 건너뛰기
Nook HD+ Top Frame Replacement
필요한 것
  1. Nook HD+ Top Frame Replacement, Removing Top Frame: 1 단계, 이미지 1/3 Nook HD+ Top Frame Replacement, Removing Top Frame: 1 단계, 이미지 2/3 Nook HD+ Top Frame Replacement, Removing Top Frame: 1 단계, 이미지 3/3
    • Wedge the plastic opening tool underneath the frame at the bottom left hand corner of the Nook HD+ and begin prying open the front frame.
    • Note there will be glue and be careful not to break the clips.
  2. Nook HD+ Top Frame Replacement, Add New Glue: 2 단계, 이미지 1/1
    • Apply glue round the inside perimeter of the new frame on the clip side.
  3. Nook HD+ Top Frame Replacement: 3 단계, 이미지 1/1
    • Line up the new frame with the bottom left hand edge of the frame lined up with the hole on the center chaise push down on the frame until all the clips pop back into the slot the belong.
    • Run finger around the entire frame making sure all the clips are in place.
    • Let glue dry.
결론
Alex Pelicas
회원 가입일: 10/17/14
283 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 2-3, Duarte Fall 2014 UMass Dartmouth, Team 2-3, Duarte Fall 2014 회원
UMASSD-DUARTE-F14S2G3
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 837
