주요 콘텐츠로 건너뛰기
Nook HD Back and Front Casing Replacement
필요한 것
  1. Nook HD Back and Front Casing Replacement, Case: 1 단계, 이미지 3개 중 1개 Nook HD Back and Front Casing Replacement, Case: 1 단계, 이미지 3개 중 2개 Nook HD Back and Front Casing Replacement, Case: 1 단계, 이미지 3개 중 3개
    • Be sure the device is powered off. Clean the device to prevent any dirt and dust from entering into the device.
    • Use the plastic opening tool to gently pry the plastic screen frame away from the screen. Run the plastic opening tool along the interior edge of the screen until the screen frame is completely separated from the glass.
    • The screen frame is held onto the Nook by a set of tab that run around the outside of the frame. There may also be a line of rubber cement around the Nook under the screen frame. If your Nook has this, you will have to dig deep to separate the frame from the Nook.
  2. Nook HD Back and Front Casing Replacement: 2 단계, 이미지 2개 중 1개 Nook HD Back and Front Casing Replacement: 2 단계, 이미지 2개 중 2개
    • Use a T5 screwdriver to remove the seventeen 5.0 millimeter screws from the back casing.
  3. Nook HD Back and Front Casing Replacement: 3 단계, 이미지 3개 중 1개 Nook HD Back and Front Casing Replacement: 3 단계, 이미지 3개 중 2개 Nook HD Back and Front Casing Replacement: 3 단계, 이미지 3개 중 3개
    • Slowly pull the back casing away from the screen and motherboard.
    • There is a cable attaching the battery in the back plate to the motherboard. Avoid detaching either end of the cable during this step.
  4. Nook HD Back and Front Casing Replacement: 4 단계, 이미지 3개 중 1개 Nook HD Back and Front Casing Replacement: 4 단계, 이미지 3개 중 2개 Nook HD Back and Front Casing Replacement: 4 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to gently unclip the wire from the pins by pulling the white connector up.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Connor Pickert
회원 가입일: 04/17/14
320 평판
안내서 2개를 작성함
Cal Poly, Team 3-43, Maness Spring 2014 Cal Poly, Team 3-43, Maness Spring 2014 회원
CPSU-MANESS-S14S3G43
5 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 6
전체 시간: 2,740
