주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nook Tablet Battery Replacement
필요한 것
    1. Nook Tablet Battery Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • Flip the Nook over.
      댓글 쓰기
    2. Nook Tablet Battery Replacement: 2 단계, 이미지 2개 중 1개 Nook Tablet Battery Replacement: 2 단계, 이미지 2개 중 2개
      • Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present.
      • Remove the tape covering the round holes to reveal two T5 Torx screws.
      • Remove the two T5 Torx screws securing the back cover.
      댓글 쓰기
    3. Nook Tablet Battery Replacement: 3 단계, 이미지 2개 중 1개 Nook Tablet Battery Replacement: 3 단계, 이미지 2개 중 2개
      • Insert the flat end of a spudger between the front panel and the rear assembly.
      • Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
      • Use a spudger to lift the the back panel from the rest of the Nook.
      댓글 쓰기
    4. Nook Tablet Battery Replacement: 4 단계, 이미지 2개 중 1개 Nook Tablet Battery Replacement: 4 단계, 이미지 2개 중 2개
      • Slide the spudger around the edges of the Nook to loosen the back panel.
      댓글 쓰기
    5. Nook Tablet Battery Replacement: 5 단계, 이미지 1개 중 1개
      • Pull the back panel off the Nook.
      댓글 쓰기
    1. Nook Tablet Battery Replacement, Screen Bezel: 6 단계, 이미지 2개 중 1개 Nook Tablet Battery Replacement, Screen Bezel: 6 단계, 이미지 2개 중 2개
      • Using the T5 Torx screwdriver, remove the ten T5 screws from around the edges of the silver midframe.
      댓글 쓰기
    2. Nook Tablet Battery Replacement: 7 단계, 이미지 2개 중 1개 Nook Tablet Battery Replacement: 7 단계, 이미지 2개 중 2개
      • Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe.
      댓글 쓰기
    1. Nook Tablet Battery Replacement, Disconnect the Battery: 8 단계, 이미지 2개 중 1개 Nook Tablet Battery Replacement, Disconnect the Battery: 8 단계, 이미지 2개 중 2개
      • Lift up the foam pad at the corner of the battery to reveal the battery connector.
      • Use a spudger or plastic opening tool to disconnect the battery cable from the motherboard.
      • These photos show a screwdriver, but we recommend using a nonconductive tool like a spudger to prevent a potential short.
      댓글 쓰기
    1. Nook Tablet Battery Replacement, Midframe: 9 단계, 이미지 1개 중 1개
      • Lift up the foam that covers the power connector and volume connector.
      • Disconnect the power and volume cables from their sockets on the motherboard.
      댓글 쓰기
    2. Nook Tablet Battery Replacement: 10 단계, 이미지 2개 중 1개 Nook Tablet Battery Replacement: 10 단계, 이미지 2개 중 2개
      • Carefully lift the silver midframe away from the motherboard and display assembly.
      • Be careful when handling the motherboard, making sure to not dislodge/shift any of its major components.
      댓글 쓰기
    1. Nook Tablet Battery Replacement, Taking Out the Battery: 11 단계, 이미지 3개 중 1개 Nook Tablet Battery Replacement, Taking Out the Battery: 11 단계, 이미지 3개 중 2개 Nook Tablet Battery Replacement, Taking Out the Battery: 11 단계, 이미지 3개 중 3개
      • Set aside the motherboard and focus on the metal backing containing the battery.
      • Use the screwdriver or plastic prying tool around the edges of the battery to pry it from its slot in the metal backing.
      • The battery may be held with adhesive. Do not panic if it feels like you are prying too hard just apply careful force until it is no longer stuck.
      • Pick up the battery and remove it making sure to free the cords in the upper left hand corner by sliding it out rather than lifting it.
      댓글 쓰기
    2. Nook Tablet Battery Replacement, Notes for Reassembly: 12 단계, 이미지 1개 중 1개
      • When replacing the motherboard make sure that the speaker assembly component (small rectangular piece) is in place. It is not attached and needs to be properly aligned.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 14명이 해당 안내서를 완성하였습니다.
작성자
15다른 기여자 명과 함께
Holly Lowe
회원 가입일: 09/26/12
238 평판
안내서 3개를 작성함
Cal Poly, Team 1-4, Propen Fall 2012 Cal Poly, Team 1-4, Propen Fall 2012 회원
CPSU-PROPEN-F12S1G4
4 회원들
안내서 14개를 작성함
2가이드 댓글
How does one disconnect the battery connection in Step 8? The photo shows it miraculously disconnected and the head of a flathead screwdriver is visible, but it doesn't show how to actually remove that connector which has some sort of interlock. Do you just pry the connector away or do you pry it up? The new battery connector has the same interlock, but gives no clue as to how one would make or remove the connector.
jjsims - 답글 공유
what a bullsh*t way to screw the public….ugh. sticking to fricking books!!!! no battery needed!!
iblobar - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 21
지난 30일: 95
전체 시간: 42,109
