주요 콘텐츠로 건너뛰기
Nook Tablet Display Replacement
필요한 것
  1. Nook Tablet Display Replacement, Back Cover: 1 단계, 이미지 1/1
    • Flip the Nook over.
  2. Nook Tablet Display Replacement: 2 단계, 이미지 1/2 Nook Tablet Display Replacement: 2 단계, 이미지 2/2
    • Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present.
    • Remove the tape covering the round holes to reveal two T5 Torx screws.
    • Remove the two T5 Torx screws securing the back cover.
    Remove stickers covering T5 screws and remove screws
    badbyz - 답글
    Also, remove the mini SD card first or you may break it taking the back off.
    54pontiac - 답글
  3. Nook Tablet Display Replacement: 3 단계, 이미지 1/2 Nook Tablet Display Replacement: 3 단계, 이미지 2/2
    • Insert the flat end of a spudger between the front panel and the rear assembly.
    • Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
    • Use a spudger to lift the the back panel from the rest of the Nook.
  4. Nook Tablet Display Replacement: 4 단계, 이미지 1/2 Nook Tablet Display Replacement: 4 단계, 이미지 2/2
    • Slide the spudger around the edges of the Nook to loosen the back panel.
  5. Nook Tablet Display Replacement: 5 단계, 이미지 1/1
    • Pull the back panel off the Nook.
  6. Nook Tablet Display Replacement, Screen Bezel: 6 단계, 이미지 1/2 Nook Tablet Display Replacement, Screen Bezel: 6 단계, 이미지 2/2
    • Using the T5 Torx screwdriver, remove the ten T5 screws from around the edges of the silver midframe.
  7. Nook Tablet Display Replacement: 7 단계, 이미지 1/2 Nook Tablet Display Replacement: 7 단계, 이미지 2/2
    • Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe.
  8. Nook Tablet Display Replacement, Disconnect the Battery: 8 단계, 이미지 1/2 Nook Tablet Display Replacement, Disconnect the Battery: 8 단계, 이미지 2/2
    • Lift up the foam pad at the corner of the battery to reveal the battery connector.
    • Use a spudger or plastic opening tool to disconnect the battery cable from the motherboard.
    • These photos show a screwdriver, but we recommend using a nonconductive tool like a spudger to prevent a potential short.
  9. Nook Tablet Display Replacement, Midframe: 9 단계, 이미지 1/1
    • Lift up the foam that covers the power connector and volume connector.
    • Disconnect the power and volume cables from their sockets on the motherboard.
  10. Nook Tablet Display Replacement: 10 단계, 이미지 1/2 Nook Tablet Display Replacement: 10 단계, 이미지 2/2
    • Carefully lift the silver midframe away from the motherboard and display assembly.
    • Be careful when handling the motherboard, making sure to not dislodge/shift any of its major components.
  11. Nook Tablet Display Replacement, Display: 11 단계, 이미지 1/2 Nook Tablet Display Replacement, Display: 11 단계, 이미지 2/2
    • Orient the mother board as shown, so that the screen is facing downwards.
    • Grab the corner of the orange strip on the right side of the mother board as shown.
    • The orange strip is adhered to the mother board, gently lift the strip so that the adhesion is broken.
    • The strip will still be attached by the circuit connection to the mother board, proceed to the next step.
  12. Nook Tablet Display Replacement: 12 단계, 이미지 1/3 Nook Tablet Display Replacement: 12 단계, 이미지 2/3 Nook Tablet Display Replacement: 12 단계, 이미지 3/3
    • The orange strip will still be attached at this point
    • Insert the end of a flat head screw driver between the connection of the strip and mother board and pry upward.
    • Grab the strip and gently pull upward to finish the disconnection.
  13. Nook Tablet Display Replacement: 13 단계, 이미지 1/2 Nook Tablet Display Replacement: 13 단계, 이미지 2/2
    • On the left side of the motherboard, you will see another orange strip, this one is taped down to the motherboard.
    • Remove the tape.
  14. Nook Tablet Display Replacement: 14 단계, 이미지 1/3 Nook Tablet Display Replacement: 14 단계, 이미지 2/3 Nook Tablet Display Replacement: 14 단계, 이미지 3/3
    • After the tape has been removed, the strip will still be attached to the motherboard by the hinge pictured here.
    • Slide the tip of a flat head screwdriver under the hinge and pry the hinge upward.
    • The orange strip should now be detached from the mother board.
  15. Nook Tablet Display Replacement: 15 단계, 이미지 1/3 Nook Tablet Display Replacement: 15 단계, 이미지 2/3 Nook Tablet Display Replacement: 15 단계, 이미지 3/3
    • The screen is adhered to the mother board at the screw holes marked
    • Break the adhesion by inserting the edge of a flat head screwdriver inbetween the motherboard and the pieces of the screen at the marked holes
    • Lift the screen from the display.
    Transfer the rainbow button and tape at the bottom of your old screen to the new screen if the new screen does not have one.
    Dave Snyder - 답글
결론
다른 12명이 해당 안내서를 완성하였습니다.
Michael Mooney
회원 가입일: 09/26/12
291 평판
안내서 1개 작성함
Cal Poly, Team 1-4, Propen Fall 2012 Cal Poly, Team 1-4, Propen Fall 2012 회원
CPSU-PROPEN-F12S1G4
4 회원들
안내서 14개 작성하였습니다
댓글 2개
Where can one get a replacement screen for the glow-light first model?
Hank - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 15
전체 시간: 32,281
