주요 콘텐츠로 건너뛰기
Nook Tablet Midframe Replacement
필요한 것
  1. Nook Tablet Midframe Replacement, Back Cover: 1 단계, 이미지 1/1
    • Flip the Nook over.
  2. Nook Tablet Midframe Replacement: 2 단계, 이미지 1/2 Nook Tablet Midframe Replacement: 2 단계, 이미지 2/2
    • Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present.
    • Remove the tape covering the round holes to reveal two T5 Torx screws.
    • Remove the two T5 Torx screws securing the back cover.
  3. Nook Tablet Midframe Replacement: 3 단계, 이미지 1/2 Nook Tablet Midframe Replacement: 3 단계, 이미지 2/2
    • Insert the flat end of a spudger between the front panel and the rear assembly.
    • Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
    • Use a spudger to lift the the back panel from the rest of the Nook.
  4. Nook Tablet Midframe Replacement: 4 단계, 이미지 1/2 Nook Tablet Midframe Replacement: 4 단계, 이미지 2/2
    • Slide the spudger around the edges of the Nook to loosen the back panel.
  5. Nook Tablet Midframe Replacement: 5 단계, 이미지 1/1
    • Pull the back panel off the Nook.
  6. Nook Tablet Midframe Replacement, Screen Bezel: 6 단계, 이미지 1/2 Nook Tablet Midframe Replacement, Screen Bezel: 6 단계, 이미지 2/2
    • Using the T5 Torx screwdriver, remove the ten T5 screws from around the edges of the silver midframe.
  7. Nook Tablet Midframe Replacement: 7 단계, 이미지 1/2 Nook Tablet Midframe Replacement: 7 단계, 이미지 2/2
    • Using a spudger or plastic opening tool, carefully pry the screen bezel away from the silver midframe.
  8. Nook Tablet Midframe Replacement, Disconnect the Battery: 8 단계, 이미지 1/2 Nook Tablet Midframe Replacement, Disconnect the Battery: 8 단계, 이미지 2/2
    • Lift up the foam pad at the corner of the battery to reveal the battery connector.
    • Use a spudger or plastic opening tool to disconnect the battery cable from the motherboard.
    • These photos show a screwdriver, but we recommend using a nonconductive tool like a spudger to prevent a potential short.
  9. Nook Tablet Midframe Replacement, Midframe: 9 단계, 이미지 1/1
    • Lift up the foam that covers the power connector and volume connector.
    • Disconnect the power and volume cables from their sockets on the motherboard.
  10. Nook Tablet Midframe Replacement: 10 단계, 이미지 1/2 Nook Tablet Midframe Replacement: 10 단계, 이미지 2/2
    • Carefully lift the silver midframe away from the motherboard and display assembly.
    • Be careful when handling the motherboard, making sure to not dislodge/shift any of its major components.
결론
Holly Lowe
회원 가입일: 09/26/12
238 평판
안내서 3개 작성하였습니다
Cal Poly, Team 1-4, Propen Fall 2012 Cal Poly, Team 1-4, Propen Fall 2012 회원
CPSU-PROPEN-F12S1G4
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 406
