주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
This guide will help you remove the circuit board from the outer telephone case. You may need to remove the circuit board to repair internal components, such as buttons.
부품
지정된 부품이 없습니다.
  1. Flip the phone over to view the back. Remove the power and phone cords. Remove the power and phone cords.
    • Flip the phone over to view the back.
    • Remove the power and phone cords.
  2. Remove the seven 8mm Phillips #2 screws.
    • Remove the seven 8mm Phillips #2 screws.
  3. Lift up the back cover slowly because there are still wires attached to the circuit board. Lifting the back cover should not require a lot of force; simply lift with your fingertips.
    • Lift up the back cover slowly because there are still wires attached to the circuit board.
    • Lifting the back cover should not require a lot of force; simply lift with your fingertips.
  4. Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
    • Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
  5. Remove the six 8mm Phillips #2 screws. Pull the speaker phone cover straight up.
    • Remove the six 8mm Phillips #2 screws.
    • Pull the speaker phone cover straight up.
  6. Remove the red and white wires from the rubber casing rim.
    • Remove the red and white wires from the rubber casing rim.
  7. Lift out the speaker and set it away from the tray that holds it. Then remove the black plastic tray at the bottom by lifting it straight up.
    • Lift out the speaker and set it away from the tray that holds it.
    • Then remove the black plastic tray at the bottom by lifting it straight up.
  8. Remove the two 8mm Phillips #2 screws.
    • Remove the two 8mm Phillips #2 screws.
  9. Pull the gray plastic casing away from the circuit board as you remove the clear, curved, plastic piece straight up. Pull the gray plastic casing away from the circuit board as you remove the clear, curved, plastic piece straight up.
    • Pull the gray plastic casing away from the circuit board as you remove the clear, curved, plastic piece straight up.
  10. There are three clips on the circuit board to un-clip. Unclip both back black clips with your fingertips. Push the middle black clip towards the bottom of the picture with a flathead screwdriver.
    • There are three clips on the circuit board to un-clip.
    • Unclip both back black clips with your fingertips.
    • Push the middle black clip towards the bottom of the picture with a flathead screwdriver.
  11. There's a brown ribbon still attached to the circuit board and phone case, so don't pull the circuit board completely off just yet. Lift the edge of the circuit board over the phone case and slightly up, so the bottom of circuit board can be viewed.
    • There's a brown ribbon still attached to the circuit board and phone case, so don't pull the circuit board completely off just yet.
    • Lift the edge of the circuit board over the phone case and slightly up, so the bottom of circuit board can be viewed.
  12. Push down each brown clip on either side of the brown metal strip using your fingertip.
    • Push down each brown clip on either side of the brown metal strip using your fingertip.
    • Detach the circuit board from the brown ribbon.
  13. Remove the clear rubber casing.
    • Remove the clear rubber casing.
    • Be careful not to flip over the front phone casing or all of the buttons will fall out.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Elizabeth
회원 가입일: 2012년 01월 21일
160 평판
안내서 3개 작성하였습니다
Cal Poly, Team 10-35, Amido Winter 2012 Cal Poly, Team 10-35, Amido Winter 2012 회원
CPSU-AMIDO-W12S10G35
4 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 1,872
