이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Flip the phone over to view the back.
Remove the power and phone cords.
Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
Remove the six 8mm Phillips #2 screws.
Pull the speaker phone cover straight up.
Lift out the speaker and set it away from the tray that holds it.
Then remove the black plastic tray at the bottom by lifting it straight up.
Pull the gray plastic casing away from the circuit board as you remove the clear, curved, plastic piece straight up.
There are three clips on the circuit board to un-clip.
Unclip both back black clips with your fingertips.
Push the middle black clip towards the bottom of the picture with a flathead screwdriver.
Lift the edge of the circuit board over the phone case and slightly up, so the bottom of circuit board can be viewed.
Push down each brown clip on either side of the brown metal strip using your fingertip.
Detach the circuit board from the brown ribbon.
다른 2명이 해당 안내서를 완성하였습니다.
