주요 콘텐츠로 건너뛰기
Nortel Networks i2004 IP Speaker Replacement
필요한 것
  1. Nortel Networks i2004 IP Speaker Replacement, Back Cover: 1 단계, 이미지 1/3 Nortel Networks i2004 IP Speaker Replacement, Back Cover: 1 단계, 이미지 2/3 Nortel Networks i2004 IP Speaker Replacement, Back Cover: 1 단계, 이미지 3/3
    • Flip the phone over to view the back.
    • Remove the power and phone cords.
  2. Nortel Networks i2004 IP Speaker Replacement: 2 단계, 이미지 1/1
    • Remove the seven 8mm Phillips #2 screws.
  3. Nortel Networks i2004 IP Speaker Replacement: 3 단계, 이미지 1/2 Nortel Networks i2004 IP Speaker Replacement: 3 단계, 이미지 2/2
    • Lift up the back cover slowly because there are still wires attached to the circuit board.
    • Lifting the back cover should not require a lot of force; simply lift with your fingertips.
  4. Nortel Networks i2004 IP Speaker Replacement: 4 단계, 이미지 1/1
    • Disconnect the rubber piece by pulling it out of the slot, freeing the back cover completely.
  5. Nortel Networks i2004 IP Speaker Replacement: 5 단계, 이미지 1/2 Nortel Networks i2004 IP Speaker Replacement: 5 단계, 이미지 2/2
    • Remove the six 8mm Phillips #2 screws.
    • Pull the speaker phone cover straight up.
  6. Nortel Networks i2004 IP Speaker Replacement, Speaker: 6 단계, 이미지 1/1
    • Lift the speaker straight up.
    • The speaker may need to be slightly wiggled in order to loosen and remove.
  7. Nortel Networks i2004 IP Speaker Replacement: 7 단계, 이미지 1/1
    • Cut the red and white wires as close to the speaker as possible.
    • Wire cutters are preferred, but normal scissors are fine too.
  8. Nortel Networks i2004 IP Speaker Replacement: 8 단계, 이미지 1/2 Nortel Networks i2004 IP Speaker Replacement: 8 단계, 이미지 2/2
    • Solder wires to new speaker.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Elizabeth
회원 가입일: 01/21/12
160 평판
안내서 3개 작성하였습니다
Cal Poly, Team 10-35, Amido Winter 2012 Cal Poly, Team 10-35, Amido Winter 2012 회원
CPSU-AMIDO-W12S10G35
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 1,145
