주요 콘텐츠로 건너뛰기
Nostalgia Electrics PCM805 Extractor Head Replacement
  1. Nostalgia Electrics PCM805 Extractor Head Replacement, Bowl: 1 단계, 이미지 1개 중 1개
    • Make sure that the device is unplugged and has not been used recently because the extractor head and bowl can be very hot.
    • Place the device on a steady table.
    • Lift and remove the rim.
  2. Nostalgia Electrics PCM805 Extractor Head Replacement: 2 단계, 이미지 3개 중 1개 Nostalgia Electrics PCM805 Extractor Head Replacement: 2 단계, 이미지 3개 중 2개 Nostalgia Electrics PCM805 Extractor Head Replacement: 2 단계, 이미지 3개 중 3개
    • Twist the bowl clockwise until it is free of the groove and lift to remove.
  3. Nostalgia Electrics PCM805 Extractor Head Replacement, Extractor Head: 3 단계, 이미지 2개 중 1개 Nostalgia Electrics PCM805 Extractor Head Replacement, Extractor Head: 3 단계, 이미지 2개 중 2개
    • Firmly grip the extractor head and slowly lift vertically to remove from the device.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Carlton
회원 가입일: 01/13/15
672 평판
안내서 5개를 작성함
USF Tampa, Team 3-5, Hickman Winter 2015 USF Tampa, Team 3-5, Hickman Winter 2015 회원
USFT-HICKMAN-W15S3G5
5 회원들
안내서 8개를 작성함
10가이드 댓글
Where can I order a new owners Manuel.? My kids or the dog ate the one it came with. I didn't save the box either.
melissaroberts67 - 답글
Where do I order a new extractor head?
lianahanson - 답글
Where do I get replacement extractor head?
lianahanson - 답글
Did anyone ever find out where you can get extractor head?
Debbie Quintero - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 28
전체 시간: 10,975
