주요 콘텐츠로 건너뛰기
Nostalgia Electrics PCM805 Heating Element
필요한 것
  1. Nostalgia Electrics PCM805 Heating Element, Bowl: 1 단계, 이미지 1/1
    • Make sure that the device is unplugged and has not been used recently because the extractor head and bowl can be very hot.
    • Place the device on a steady table.
    • Lift and remove the rim.
  2. Nostalgia Electrics PCM805 Heating Element: 2 단계, 이미지 1/3 Nostalgia Electrics PCM805 Heating Element: 2 단계, 이미지 2/3 Nostalgia Electrics PCM805 Heating Element: 2 단계, 이미지 3/3
    • Twist the bowl clockwise until it is free of the groove and lift to remove.
  3. Nostalgia Electrics PCM805 Heating Element, Extractor Head: 3 단계, 이미지 1/2 Nostalgia Electrics PCM805 Heating Element, Extractor Head: 3 단계, 이미지 2/2
    • Firmly grip the extractor head and slowly lift vertically to remove from the device.
  4. Nostalgia Electrics PCM805 Heating Element, Unscrewing the base: 4 단계, 이미지 1/2 Nostalgia Electrics PCM805 Heating Element, Unscrewing the base: 4 단계, 이미지 2/2
    • Unplug the device before following this guide.
    • First, place the device on its side, making sure the switch is not facing down.
    • Remove the eight 12mm Phillips #02 screws from the base.
  5. Nostalgia Electrics PCM805 Heating Element: 5 단계, 이미지 1/1
    • Gently separate the panel from the device.
    • Be sure not to tug at the wires that are still connected.
  6. Nostalgia Electrics PCM805 Heating Element, Nostalgia Electrics PCM805 Wiring Teardown: 6 단계, 이미지 1/2 Nostalgia Electrics PCM805 Heating Element, Nostalgia Electrics PCM805 Wiring Teardown: 6 단계, 이미지 2/2
    • Locate the tie strap holding the wires and cut with a pair of scissors.
    • Use care not to snip the wires.
  7. Nostalgia Electrics PCM805 Heating Element: 7 단계, 이미지 1/3 Nostalgia Electrics PCM805 Heating Element: 7 단계, 이미지 2/3 Nostalgia Electrics PCM805 Heating Element: 7 단계, 이미지 3/3
    • Make note of the wiring arrangement of each bundle before this step.
    • Using wire cutters, cut each wire as close to the wire connector as possible.
    • Cut the wires in both bundles.
    • To reassemble the cotton candy maker after cutting the wires, follow our rewiring guide.
  8. Nostalgia Electrics PCM805 Heating Element, Heating Element: 8 단계, 이미지 1/2 Nostalgia Electrics PCM805 Heating Element, Heating Element: 8 단계, 이미지 2/2
    • Remove the six 10mm Phillips #02 screws that secure the metal housing covering the heating element.
    • Remove the metal housing.
  9. Nostalgia Electrics PCM805 Heating Element: 9 단계, 이미지 1/2 Nostalgia Electrics PCM805 Heating Element: 9 단계, 이미지 2/2
    • Remove the four 9mm Phillips #02 screws that secure the heating element to the rest of the device.
  10. Nostalgia Electrics PCM805 Heating Element: 10 단계, 이미지 1/2 Nostalgia Electrics PCM805 Heating Element: 10 단계, 이미지 2/2
    • Line up the prongs on the motor shaft with the slots in either side of the hole in the heating element and lift it off the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nicholas Fazio
회원 가입일: 01/13/15
194 평판
안내서 1개 작성함
USF Tampa, Team 3-5, Hickman Winter 2015 USF Tampa, Team 3-5, Hickman Winter 2015 회원
USFT-HICKMAN-W15S3G5
5 회원들
안내서 8개 작성하였습니다
댓글 한 개
Where can I buy a replacement heating element?
Eric P. Rose - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 19
전체 시간: 5,370
