주요 콘텐츠로 건너뛰기
Nostalgia Electrics PCM805 Motor Replacement
필요한 것
  1. Nostalgia Electrics PCM805 Motor Replacement, Unscrewing the base: 1 단계, 이미지 2개 중 1개 Nostalgia Electrics PCM805 Motor Replacement, Unscrewing the base: 1 단계, 이미지 2개 중 2개
    • Unplug the device before following this guide.
    • First, place the device on its side, making sure the switch is not facing down.
    • Remove the eight 12mm Phillips #02 screws from the base.
  2. Nostalgia Electrics PCM805 Motor Replacement: 2 단계, 이미지 1개 중 1개
    • Gently separate the panel from the device.
    • Be sure not to tug at the wires that are still connected.
  3. Nostalgia Electrics PCM805 Motor Replacement, Nostalgia Electrics PCM805 Wiring Teardown: 3 단계, 이미지 2개 중 1개 Nostalgia Electrics PCM805 Motor Replacement, Nostalgia Electrics PCM805 Wiring Teardown: 3 단계, 이미지 2개 중 2개
    • Locate the tie strap holding the wires and cut with a pair of scissors.
    • Use care not to snip the wires.
  4. Nostalgia Electrics PCM805 Motor Replacement: 4 단계, 이미지 3개 중 1개 Nostalgia Electrics PCM805 Motor Replacement: 4 단계, 이미지 3개 중 2개 Nostalgia Electrics PCM805 Motor Replacement: 4 단계, 이미지 3개 중 3개
    • Make note of the wiring arrangement of each bundle before this step.
    • Using wire cutters, cut each wire as close to the wire connector as possible.
    • Cut the wires in both bundles.
    • To reassemble the cotton candy maker after cutting the wires, follow our rewiring guide.
  5. Nostalgia Electrics PCM805 Motor Replacement, Motor: 5 단계, 이미지 2개 중 1개 Nostalgia Electrics PCM805 Motor Replacement, Motor: 5 단계, 이미지 2개 중 2개
    • Remove the four 12mm Phillips #02 screws to free the motor housing.
  6. Nostalgia Electrics PCM805 Motor Replacement: 6 단계, 이미지 2개 중 1개 Nostalgia Electrics PCM805 Motor Replacement: 6 단계, 이미지 2개 중 2개
    • Line up the prongs on the motor shaft with the holes in the heating element and pull the motor out.
결론
작성자
2다른 기여자 명과 함께
Joshua Harriger
회원 가입일: 01/13/15
309 평판
안내서 2개를 작성함
USF Tampa, Team 3-5, Hickman Winter 2015 USF Tampa, Team 3-5, Hickman Winter 2015 회원
USFT-HICKMAN-W15S3G5
5 회원들
안내서 8개를 작성함
2가이드 댓글
Hello.
I purchased this item in a red variation from VAT19. It does not work but the light comes on. I live in the UK and we have a higher Voltage(240V) running in our domestic supply.
Something may have blown.
Can you advise what is it likely to be?
If there is a part that we can replace, can you advise which one and where I can purchase it from please?
Moh - 답글
Hi, I need the cotton machine from the nostalgia cotton sugar machine and I don't know where to get it. can you help me? My email is terebcn18@hotmail.com
Teresa gb - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 10
전체 시간: 3,434
