소개
This guide will describe the maintenance of the device.
도구
부품
부품은 필요하지 않습니다.
Now that the power switch is disconnected from the popper, you will need to remove the white top.
Gently remove the heating component from the popper.
Unscrew the four screws (11mm Philips #2 screws) that connect the white top to the housing.
Now that the white top is disconnected from the housing, remove the heating component from inside the device.
Remove the heating coil out of the heating component.
거의 끝나갑니다!
결론
