주요 콘텐츠로 건너뛰기
Nostalgia Electrics RHP-310 Power Switch Replacement
필요한 것
  1. Nostalgia Electrics RHP-310 Power Switch Replacement, Power Switch: 1 단계, 이미지 1/1
    • Unplug the popper.
    • Lift the lid up to remove it.
  2. Nostalgia Electrics RHP-310 Power Switch Replacement: 2 단계, 이미지 1/1
    • Lay the popper on its side.
    • Remove the five 12mm Philips #2 screws around the perimeter of the base with the Phillips #2 screwdriver.
    • Remove the two 15mm Philips #2 screws in the center of the base with the Phillips #2 screwdriver.
    • Put the removed screws in a safe place, they will be needed later to reattach the housing to the base.
  3. Nostalgia Electrics RHP-310 Power Switch Replacement: 3 단계, 이미지 1/1
    • Flip the base over to view the interior of the base panel.
    • Unscrew the two 10 mm Philips #2 screws from the base panel.
    • Remove the base and set it aside.
  4. Nostalgia Electrics RHP-310 Power Switch Replacement: 4 단계, 이미지 1/2 Nostalgia Electrics RHP-310 Power Switch Replacement: 4 단계, 이미지 2/2
    • Locate the power switch connected to the side of the housing.
    • Pinch the sides of the power switch.
    • Push the power button up and out of the housing.
  5. Nostalgia Electrics RHP-310 Power Switch Replacement: 5 단계, 이미지 1/1
    • Remove the wires connected to the power switch that should be detached from the housing.
    • Gently pry the wires loose from the power switch with the plastic opening tool.
    • The wires should easily pop out from the power switch.
  6. Nostalgia Electrics RHP-310 Power Switch Replacement: 6 단계, 이미지 1/1
    • Remove the power switch from the housing unit.
    • You can now replace the power switch, if necessary.
결론
Dana Clarke
회원 가입일: 09/26/12
50 평판
안내서 6개 작성하였습니다
Cal Poly, Team 16-57, Forte Fall 2012 Cal Poly, Team 16-57, Forte Fall 2012 회원
CPSU-FORTE-F12S16G57
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 1,050
