주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Nostalgia Electrics RHP-310 Replacing Fan Replacement
필요한 것
  1. Nostalgia Electrics RHP-310 Replacing Fan Replacement, Power Switch: 1 단계, 이미지 1/1
    • Unplug the popper.
    • Lift the lid up to remove it.
  2. Nostalgia Electrics RHP-310 Replacing Fan Replacement: 2 단계, 이미지 1/1
    • Lay the popper on its side.
    • Remove the five 12mm Philips #2 screws around the perimeter of the base with the Phillips #2 screwdriver.
    • Remove the two 15mm Philips #2 screws in the center of the base with the Phillips #2 screwdriver.
    • Put the removed screws in a safe place, they will be needed later to reattach the housing to the base.
  3. Nostalgia Electrics RHP-310 Replacing Fan Replacement: 3 단계, 이미지 1/1
    • Flip the base over to view the interior of the base panel.
    • Unscrew the two 10 mm Philips #2 screws from the base panel.
    • Remove the base and set it aside.
  4. Nostalgia Electrics RHP-310 Replacing Fan Replacement: 4 단계, 이미지 1/2 Nostalgia Electrics RHP-310 Replacing Fan Replacement: 4 단계, 이미지 2/2
    • Locate the power switch connected to the side of the housing.
    • Pinch the sides of the power switch.
    • Push the power button up and out of the housing.
  5. Nostalgia Electrics RHP-310 Replacing Fan Replacement: 5 단계, 이미지 1/1
    • Remove the wires connected to the power switch that should be detached from the housing.
    • Gently pry the wires loose from the power switch with the plastic opening tool.
    • The wires should easily pop out from the power switch.
  6. Nostalgia Electrics RHP-310 Replacing Fan Replacement: 6 단계, 이미지 1/1
    • Remove the power switch from the housing unit.
    • You can now replace the power switch, if necessary.
  7. Nostalgia Electrics RHP-310 Replacing Fan Replacement, Replacing Housing: 7 단계, 이미지 1/2 Nostalgia Electrics RHP-310 Replacing Fan Replacement, Replacing Housing: 7 단계, 이미지 2/2
    • Gently remove the heating component from the popper.
    • Unscrew the four screws (11mm Philips #2 screws) that connect the white top to the housing.
    • Save the screws from this step. You will need them to connect the new housing to the white top.
  8. Nostalgia Electrics RHP-310 Replacing Fan Replacement: 8 단계, 이미지 1/1
    • Remove the white top from the housing.
  9. Nostalgia Electrics RHP-310 Replacing Fan Replacement, Replacing Fan: 9 단계, 이미지 1/1
    • Now that the white top is disconnected from the housing, remove the heating component from inside the device.
  10. Nostalgia Electrics RHP-310 Replacing Fan Replacement: 10 단계, 이미지 1/1
    • Unscrew the three screws (10 mm Philips #2 screws) that hold the heating component together.
  11. Nostalgia Electrics RHP-310 Replacing Fan Replacement: 11 단계, 이미지 1/1
    • Make sure to keep the screws. You will need them to put the heating component back together.
    • Pull the heating component apart.
  12. Nostalgia Electrics RHP-310 Replacing Fan Replacement: 12 단계, 이미지 1/2 Nostalgia Electrics RHP-310 Replacing Fan Replacement: 12 단계, 이미지 2/2
    • Locate the fan.
    • Pull the fan off the motor firmly but gently.
    • When you pull the fan off the motor, be careful. Do not pull to hard or you will break the motor.
  13. Nostalgia Electrics RHP-310 Replacing Fan Replacement: 13 단계, 이미지 1/1
    • You can now replace the fan.
    • If there is debris stuck in the fan, you can easily clean it out from the fan in this step.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Dana Clarke
회원 가입일: 09/26/12
50 평판
안내서 6개 작성하였습니다
Cal Poly, Team 16-57, Forte Fall 2012 Cal Poly, Team 16-57, Forte Fall 2012 회원
CPSU-FORTE-F12S16G57
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 784
