주요 콘텐츠로 건너뛰기
Nostalgia GCM200 Heating Bowl Replacement
필요한 것
  1. Nostalgia GCM200 Heating Bowl  Replacement, Nostalgia GCM200 Disassembly: 1 단계, 이미지 1/2 Nostalgia GCM200 Heating Bowl  Replacement, Nostalgia GCM200 Disassembly: 1 단계, 이미지 2/2
    • Remove the two 1.3 mm Phillips #2 screws.
    • Remove the S6 spanner screw.
    • Carefully place these three screws somewhere safe to use later in reassembly.
  2. Nostalgia GCM200 Heating Bowl  Replacement: 2 단계, 이미지 1/1
    • Split the device in half to expose the internal parts of the device.
    • Again, there are two more Phillips screws to remove.
  3. Nostalgia GCM200 Heating Bowl  Replacement: 3 단계, 이미지 1/1
    • Remove the two screws from both sides of the heating coil.
  4. Nostalgia GCM200 Heating Bowl  Replacement, Heating Bowl: 4 단계, 이미지 1/1
    • Remove the heating bowl from the plastic housing.
결론
Follow the instruction and you will know how to replace the bowl for this device
다른 3명이 해당 안내서를 완성하였습니다.
Xingdi Zhou
회원 가입일: 06/27/17
466 평판
안내서 3개 작성하였습니다
UW Tacoma, Team S1-G4, Liner Summer 2017 UW Tacoma, Team S1-G4, Liner Summer 2017 회원
UWT-LINER-SU17S1G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 7
전체 시간: 151
