주요 콘텐츠로 건너뛰기
Nostalgia GCM200 Power Cable Replacement
필요한 것
  1. Nostalgia GCM200 Power Cable Replacement, Nostalgia GCM200 Disassembly: 1 단계, 이미지 1/2 Nostalgia GCM200 Power Cable Replacement, Nostalgia GCM200 Disassembly: 1 단계, 이미지 2/2
    • Remove the two 1.3 mm Phillips #2 screws.
    • Remove the S6 spanner screw.
    • Carefully place these three screws somewhere safe to use later in reassembly.
  2. Nostalgia GCM200 Power Cable Replacement: 2 단계, 이미지 1/1
    • Split the device in half to expose the internal parts of the device.
    • Again, there are two more Phillips screws to remove.
  3. Nostalgia GCM200 Power Cable Replacement: 3 단계, 이미지 1/1
    • Remove the two screws from both sides of the heating coil.
  4. Nostalgia GCM200 Power Cable Replacement, Power Cable: 4 단계, 이미지 1/1
    • Remove (flexible) plastic sleeves from the inside end of the power cable.
    • You might want to use force, pull out while shaking it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Praful Busa
회원 가입일: 06/25/17
267 평판
안내서 2개 작성하였습니다
UW Tacoma, Team S1-G4, Liner Summer 2017 UW Tacoma, Team S1-G4, Liner Summer 2017 회원
UWT-LINER-SU17S1G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 240
