주요 콘텐츠로 건너뛰기
Novatel MiFi 2 4G LTE Hotspot Battery Replacement
  1. Novatel MiFi 2 4G LTE Hotspot  Battery Replacement, Battery Cover: 1 단계, 이미지 1/3 Novatel MiFi 2 4G LTE Hotspot  Battery Replacement, Battery Cover: 1 단계, 이미지 2/3 Novatel MiFi 2 4G LTE Hotspot  Battery Replacement, Battery Cover: 1 단계, 이미지 3/3
    • Unplug the charger from your Novatel Hotspot device.
    • Place the Novatel Hotspot device face down on a flat, clean surface.
    • Place your thumb under the latch of the black plastic battery cover as shown.
    • Remove the battery cover. This will require some force.
  2. Novatel MiFi 2 4G LTE Hotspot  Battery Replacement, Battery: 2 단계, 이미지 1/2 Novatel MiFi 2 4G LTE Hotspot  Battery Replacement, Battery: 2 단계, 이미지 2/2
    • Gently place your thumb on the right side of the battery as shown.
    • Remove the battery from its socket by lifting it up and out.
결론
GerardFoley
회원 가입일: 10/08/18
351 평판
안내서 4개 작성하였습니다
Marist, Team S1-G5, Chaterdon Fall 2018 Marist, Team S1-G5, Chaterdon Fall 2018 회원
MARS-CHATERDON-F18S1G5
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 12
전체 시간: 612
