주요 콘텐츠로 건너뛰기
Novatel MiFi 2 4G LTE Hotspot SD Card Replacement
  1. Novatel MiFi 2 4G LTE Hotspot  SD Card  Replacement, SD Card: 1 단계, 이미지 1/2 Novatel MiFi 2 4G LTE Hotspot  SD Card  Replacement, SD Card: 1 단계, 이미지 2/2
    • Unplug the charger from your Novatel Hotspot device.
    • Place the Novatel Hotspot device face down on a flat, clean surface.
    • Locate the rubber SD Card cover on the bottom left hand side of the device. The cover is labeled “Micro SD.”
  2. Novatel MiFi 2 4G LTE Hotspot  SD Card  Replacement: 2 단계, 이미지 1/1
    • Open the SD Card cover by placing your finger on the top of the rubber cover and pulling it down.
    • Remove the faulty SD card from its slot by sliding it out with your finger.
    • This guide does not feature an actual SD Card.
결론
GerardFoley
회원 가입일: 10/08/18
351 평판
안내서 4개 작성하였습니다
Marist, Team S1-G5, Chaterdon Fall 2018 Marist, Team S1-G5, Chaterdon Fall 2018 회원
MARS-CHATERDON-F18S1G5
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 10
전체 시간: 126
