소개
This guide will show you step by step how to remove a dead SIM Card from your Novatel Hotspot device. This requires the removal of the black plastic battery cover and the battery.
도구
도구는 필요하지 않습니다.
부품
부품은 필요하지 않습니다.
  1. Unplug the charger from your Novatel Hotspot device. Place the Novatel Hotspot device face down on a flat, clean surface. Place your thumb under the latch of the black plastic battery cover as shown.
    • Unplug the charger from your Novatel Hotspot device.
    • Place the Novatel Hotspot device face down on a flat, clean surface.
    • Place your thumb under the latch of the black plastic battery cover as shown.
    • Remove the battery cover. This will require some force.
  2. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  3. Gently place your thumb on the right side of the battery as shown. Remove the battery from its socket by lifting it up and out.
    • Gently place your thumb on the right side of the battery as shown.
    • Remove the battery from its socket by lifting it up and out.
  4. Once the battery has been removed, the SIM Card slot can be accessed. Carefully take out the dead SIM Card by lifting it from its position with your fingers. Carefully take out the dead SIM Card by lifting it from its position with your fingers.
    • Once the battery has been removed, the SIM Card slot can be accessed.
    • Carefully take out the dead SIM Card by lifting it from its position with your fingers.
결론
GerardFoley
회원 가입일: 2018년 10월 08일
351 평판
안내서 4개 작성하였습니다
Marist, Team S1-G5, Chaterdon Fall 2018 Marist, Team S1-G5, Chaterdon Fall 2018 회원
MARS-CHATERDON-F18S1G5
3 회원들
안내서 4개 작성하였습니다
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 2
전체 시간: 54
