소개
After many charging cycles, your battery can wear out and eventually lose its ability to hold charge. When that happens, you will need to replace the battery to keep using your Mifi.
필요한 것
Remove the rear cover by pressing down on the cover and pulling it away from the device.
거의 끝나갑니다!
Charge your new battery and you are ready to use your Mifi again.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
