주요 콘텐츠로 건너뛰기
Novatel MiFi 2200 Case Replacement
필요한 것
  1. Novatel MiFi 2200 Case Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the rear cover by pressing down on the cover and pulling it away from the device.
  2. Novatel MiFi 2200 Case Replacement: 2 단계, 이미지 1/1
    • Place your finger on the back of the battery located near the edge of the device.
    • Push your finger into the battery and lift up to pop the battery out of the device.
  3. Novatel MiFi 2200 Case Replacement, Case: 3 단계, 이미지 1/1
    • Using a metal spudger, pry open the device around the seam between the front and back cover.
    • It may be difficult to split apart, so use force with caution.
    • It may seem like you are breaking the device, but you will only be breaking the adhesive lining that keeps the device sealed.
  4. Novatel MiFi 2200 Case Replacement: 4 단계, 이미지 1/1
    • Once the seal has been broken all the way around, open the cases using your hands.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Justin Russo
회원 가입일: 04/15/12
196 평판
안내서 3개 작성하였습니다
Cal Poly, Team 7-36, Maness Spring 2012 Cal Poly, Team 7-36, Maness Spring 2012 회원
CPSU-MANESS-S12S7G36
5 회원들
안내서 5개 작성하였습니다
댓글 한 개
If case gets damaged, is there a place to but the case
Snehraj Merchant - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 12
전체 시간: 1,541
