주요 콘텐츠로 건너뛰기
Novatel MiFi 2200 Circuit Board Replacement
필요한 것
  1. Novatel MiFi 2200 Circuit Board Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the rear cover by pressing down on the cover and pulling it away from the device.
  2. Novatel MiFi 2200 Circuit Board Replacement: 2 단계, 이미지 1/1
    • Place your finger on the back of the battery located near the edge of the device.
    • Push your finger into the battery and lift up to pop the battery out of the device.
  3. Novatel MiFi 2200 Circuit Board Replacement, Case: 3 단계, 이미지 1/1
    • Using a metal spudger, pry open the device around the seam between the front and back cover.
    • It may be difficult to split apart, so use force with caution.
    • It may seem like you are breaking the device, but you will only be breaking the adhesive lining that keeps the device sealed.
  4. Novatel MiFi 2200 Circuit Board Replacement: 4 단계, 이미지 1/1
    • Once the seal has been broken all the way around, open the cases using your hands.
  5. Novatel MiFi 2200 Circuit Board Replacement, Circuit Board: 5 단계, 이미지 1/1
    • To disconnect the antenna, pull up on the antenna's connection to the circuit board until it pops off.
  6. Novatel MiFi 2200 Circuit Board Replacement: 6 단계, 이미지 1/1
    • Simply pick up the circuit board with your fingers and remove it from the case.
  7. Novatel MiFi 2200 Circuit Board Replacement: 7 단계, 이미지 1/3 Novatel MiFi 2200 Circuit Board Replacement: 7 단계, 이미지 2/3 Novatel MiFi 2200 Circuit Board Replacement: 7 단계, 이미지 3/3
    • Apply double-sided stick tape to the inner top and bottom halves of the device along the seam that was previously unsealed.
    • Snap the two halves together along the adhesive line to reconnect it as it previously was.
결론
After the circuit board is replaced the device should function properly again. When reassembling the device, keep in mind that you will need adhesive to keep the device together.
다른 6명이 해당 안내서를 완성하였습니다.
Justin Russo
회원 가입일: 04/15/12
196 평판
안내서 3개 작성하였습니다
Cal Poly, Team 7-36, Maness Spring 2012 Cal Poly, Team 7-36, Maness Spring 2012 회원
CPSU-MANESS-S12S7G36
5 회원들
안내서 5개 작성하였습니다
댓글 3개
Hello, where do you purchase the new circuit board?
David - 답글
I've tried every thing to get this device to work properly. Sic results. Sic.
Clennis Jones - 답글
Where and how can I get this thing replaced?
Clennis Jones - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 4
전체 시간: 2,187
