주요 콘텐츠로 건너뛰기
NuVision 10.1 Atom Motherboard Replacement
필요한 것
  1. NuVision 10.1 Atom Motherboard Replacement, Camera: 1 단계, 이미지 1/3 NuVision 10.1 Atom Motherboard Replacement, Camera: 1 단계, 이미지 2/3 NuVision 10.1 Atom Motherboard Replacement, Camera: 1 단계, 이미지 3/3
    • Turn the device screen side down.
    • Carefully remove the back piece with the iFixit opening tool.
  2. NuVision 10.1 Atom Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove the yellow tape covering the motherboard gently with your fingers.
  3. NuVision 10.1 Atom Motherboard Replacement: 3 단계, 이미지 1/3 NuVision 10.1 Atom Motherboard Replacement: 3 단계, 이미지 2/3 NuVision 10.1 Atom Motherboard Replacement: 3 단계, 이미지 3/3
    • Pull the camera plug upward and away from the motherboard with your fingers.
    • Gently pull the camera from the device. The camera is held by tension.
  4. NuVision 10.1 Atom Motherboard Replacement, Speaker: 4 단계, 이미지 1/1
    • Carefully remove silver tape with your fingers.
  5. NuVision 10.1 Atom Motherboard Replacement: 5 단계, 이미지 1/2 NuVision 10.1 Atom Motherboard Replacement: 5 단계, 이미지 2/2
    • Remove speakers gently using your fingers, they pop out easily.
    • Disconnect cords attached to the speaker from white pod.
  6. NuVision 10.1 Atom Motherboard Replacement, Motherboard: 6 단계, 이미지 1/1
    • Disconnect the press-fit black and red curly wire from where it connects on the motherboard.
  7. NuVision 10.1 Atom Motherboard Replacement: 7 단계, 이미지 1/3 NuVision 10.1 Atom Motherboard Replacement: 7 단계, 이미지 2/3 NuVision 10.1 Atom Motherboard Replacement: 7 단계, 이미지 3/3
    • Gently remove the battery's three ZIF connectors from the motherboard. Use your fingers.
    • Be careful not to puncture the battery.
  8. NuVision 10.1 Atom Motherboard Replacement: 8 단계, 이미지 1/2 NuVision 10.1 Atom Motherboard Replacement: 8 단계, 이미지 2/2
    • Disconnect the battery's bundled cable connector from the motherboard with fingers.
  9. NuVision 10.1 Atom Motherboard Replacement: 9 단계, 이미지 1/3 NuVision 10.1 Atom Motherboard Replacement: 9 단계, 이미지 2/3 NuVision 10.1 Atom Motherboard Replacement: 9 단계, 이미지 3/3
    • Remove the four black 3.32mm screws on the corners of the motherboard using the Phillips #000 screwdriver. The motherboard should come out easily.
결론
Laila Schulz
회원 가입일: 02/14/19
219 평판
안내서 1개 작성함
USF Tampa, Team S1-G5, Leahy Spring 2019 USF Tampa, Team S1-G5, Leahy Spring 2019 회원
USFT-LEAHY-S19S1G5
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 11
전체 시간: 449
