소개
If you've noticed that your camera quality has worsened or that your camera has cracked, this guide will walk you through how to replace the NuVision Duo 11 camera. It does not take much effort and will only require a metal spudger!
필요한 것
Place the flat end of a nylon spudger in the gap between the cover and the rest of the device.
Slide the spudger down each side until you hear numerous clicks.
Remove the back panel from the tablet.
거의 끝나갑니다!
결론
