주요 콘텐츠로 건너뛰기
NuVision TM1088 Motherboard Replacement
필요한 것
  1. NuVision TM1088 Motherboard Replacement, Rear Cover: 1 단계, 이미지 1/1
    • Place the plastic opening tool between the front and rear cover and pry up on each corner of the cover.
  2. NuVision TM1088 Motherboard Replacement, Motherboard: 2 단계, 이미지 1/1
    • Remove the two plugs for the screen by pulling up and away from the motherboard.
  3. NuVision TM1088 Motherboard Replacement: 3 단계, 이미지 1/1
    • Remove the plug for the cameras by pulling the plug up and away from the motherboard.
  4. NuVision TM1088 Motherboard Replacement: 4 단계, 이미지 1/1
    • Melt solder and remove red and black wires leading to the battery.
  5. NuVision TM1088 Motherboard Replacement: 5 단계, 이미지 1/1
    • Melt the solder on the black and gray wires and remove wires from motherboard.
  6. NuVision TM1088 Motherboard Replacement: 6 단계, 이미지 1/1
    • Melt the solder and remove the red and black wires leading to the speaker.
  7. NuVision TM1088 Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the four 4 mm Phillips head screws holding in the motherboard.
  8. NuVision TM1088 Motherboard Replacement: 8 단계, 이미지 1/1
    • Lift the motherboard away from the front cover assembly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nathaniel Nasman
회원 가입일: 03/23/15
750 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 1-1, Miles Spring 2015 UMass Dartmouth, Team 1-1, Miles Spring 2015 회원
UMASSD-MILES-S15S1G1
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 19
전체 시간: 1,665
