주요 콘텐츠로 건너뛰기
NuVision TM800A510L Charging Port Replacement
필요한 것
  1. NuVision TM800A510L Charging Port Replacement, Charging Port: 1 단계, 이미지 2개 중 1개 NuVision TM800A510L Charging Port Replacement, Charging Port: 1 단계, 이미지 2개 중 2개
    • Use a Heat Gun to loosen the adhesive on the underside of the back cover.
    • Use some prying tools to lift the back cover off of the device.
    • I recommend heating up the device up to 'just barely too hot to touch' and then prying sides up one at a time.
    • Although, you can use either plastic or metal prying tools, metal prying tools may scratch the device. Make sure not to damage power and volume buttons when prying the cover off as well.
  2. NuVision TM800A510L Charging Port Replacement: 2 단계, 이미지 1개 중 1개
    • Unscrew the motherboard.
  3. NuVision TM800A510L Charging Port Replacement: 3 단계, 이미지 1개 중 1개
    • Make sure all ribbons are disconnected.
  4. NuVision TM800A510L Charging Port Replacement: 4 단계, 이미지 2개 중 1개 NuVision TM800A510L Charging Port Replacement: 4 단계, 이미지 2개 중 2개
    • Desolder the Motherboard- this will make it easier to get to the charging port without breaking any cords.
    • Flip the Motherboard over and desolder the charging port from Motherboard.
결론
작성자
3다른 기여자 명과 함께
Kelsey Riggs
회원 가입일: 01/25/17
486 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 7
전체 시간: 2,059
