소개
Most of your time will be getting the back off of the device. The cameras are held down with a little adhesive but are relatively easy to remove.
필요한 것
Use a Heat Gun to heat the sides of the device one at a time. The Heat Gun will loosen the adhesive.
Use thin tools to pry the back of the device off.
Be advised that you will need to replace the adhesive.
다른 한 분이 해당 안내서를 완성하였습니다.
