주요 콘텐츠로 건너뛰기
NuVision TM800A510L Rear Camera Replacement
필요한 것
  1. NuVision TM800A510L Rear Camera Replacement, Rear Camera: 1 단계, 이미지 2개 중 1개 NuVision TM800A510L Rear Camera Replacement, Rear Camera: 1 단계, 이미지 2개 중 2개
    • Use a Heat Gun to heat the sides of the device one at a time. The Heat Gun will loosen the adhesive.
    • Use thin tools to pry the back of the device off.
    • Metal tools may work best but may also scratch the device. Plastic prying tools can also be used.
    • Be careful around the power and volume buttons.
  2. NuVision TM800A510L Rear Camera Replacement: 2 단계, 이미지 1개 중 1개
    • There are two different cameras and each have different ribbons.
    • Unlock both ribbons by flipping the black bar up.
  3. NuVision TM800A510L Rear Camera Replacement: 3 단계, 이미지 2개 중 1개 NuVision TM800A510L Rear Camera Replacement: 3 단계, 이미지 2개 중 2개
    • The camera facing towards the table lifts out easily, so go ahead and take that one out.
    • This works out well, if this is the camera you are most concerned about.
    • If you are more concerned the one facing you, move on to the next step.
  4. NuVision TM800A510L Rear Camera Replacement: 4 단계, 이미지 2개 중 1개 NuVision TM800A510L Rear Camera Replacement: 4 단계, 이미지 2개 중 2개
    • This camera is held down with adhesive, so you must be careful when prying it.
    • GO SLOW!
    • Camera pulls up and out of its slot easily.
결론
Be advised that you will need to replace the adhesive.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Kelsey Riggs
회원 가입일: 01/25/17
486 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 439
