주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Numark N4 Audio Jack Replacement
필요한 것
  1. Numark N4 Audio Jack Replacement, Numark N4 Disassembly: 1 단계, 이미지 1개 중 1개
    • Turn the Numark N4 over so that the bottom panel is facing upwards.
    • Loosen and remove the 17 12mm screws from the bottom panel using a Phillips #2 screwdriver.
  2. Numark N4 Audio Jack Replacement: 2 단계, 이미지 1개 중 1개
    • Using your fingers, gently pull apart the two panels of the device until you feel resistance from the cables.
  3. Numark N4 Audio Jack Replacement: 3 단계, 이미지 1개 중 1개
    • Using your fingers, gently unplug the larger ribbon cable as pictured.
  4. Numark N4 Audio Jack Replacement: 4 단계, 이미지 1개 중 1개
    • Using your fingers, gently unplug the smaller ribbon cable as pictured.
  5. Numark N4 Audio Jack Replacement: 5 단계, 이미지 1개 중 1개
    • Using your fingers, gently unplug the yellow and red cable as pictured.
  6. Numark N4 Audio Jack Replacement: 6 단계, 이미지 1개 중 1개
    • Open the two panels completely, gently placing each side on your working area to avoid damage to the buttons on the outside face.
  7. Numark N4 Audio Jack Replacement, Audio Jack: 7 단계, 이미지 1개 중 1개
    • Turn the panel around so that the audio jack is facing forward as shown.
  8. Numark N4 Audio Jack Replacement: 8 단계, 이미지 1개 중 1개
    • Using a soldering station, carefully desolder the connection points around the audio jack and remove it.
    • To review soldering safety and techniques, please visit 연결부 납땜 및 납제거 방법.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Erik Charlton
회원 가입일: 10/10/17
873 평판
안내서 5개를 작성함
USF Tampa, Team S13-G11, Cagle Fall 2017 USF Tampa, Team S13-G11, Cagle Fall 2017 회원
USFT-CAGLE-F17S13G11
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 799
