주요 콘텐츠로 건너뛰기
Numark TT1600 Tone Arm Replacement
필요한 것
  1. Numark TT1600 Tone Arm Replacement, Tone Arm: 1 단계, 이미지 1/2 Numark TT1600 Tone Arm Replacement, Tone Arm: 1 단계, 이미지 2/2
    • Flip over the turntable and remove the 9 screws on the outer edges.
  2. Numark TT1600 Tone Arm Replacement: 2 단계, 이미지 1/1
    • Remove the back cover by pulling it apart.
  3. Numark TT1600 Tone Arm Replacement: 3 단계, 이미지 1/3 Numark TT1600 Tone Arm Replacement: 3 단계, 이미지 2/3 Numark TT1600 Tone Arm Replacement: 3 단계, 이미지 3/3
    • Remove the clip located on the backside of the audio jack housing by gently pulling it out.
    • There will be some resistance but continue to pull gently.
    • The clip is located right underneath the audio jacks.
  4. Numark TT1600 Tone Arm Replacement: 4 단계, 이미지 1/3 Numark TT1600 Tone Arm Replacement: 4 단계, 이미지 2/3 Numark TT1600 Tone Arm Replacement: 4 단계, 이미지 3/3
    • Remove the screw that connects the black wire of the tone arm to the base of the audio jack housing.
  5. Numark TT1600 Tone Arm Replacement: 5 단계, 이미지 1/2 Numark TT1600 Tone Arm Replacement: 5 단계, 이미지 2/2
    • Gently pull the wire that you just unscrewed to release it from the clip.
  6. Numark TT1600 Tone Arm Replacement: 6 단계, 이미지 1/3 Numark TT1600 Tone Arm Replacement: 6 단계, 이미지 2/3 Numark TT1600 Tone Arm Replacement: 6 단계, 이미지 3/3
    • Remove the two screws connecting the circuit board to the tone arm.
  7. Numark TT1600 Tone Arm Replacement: 7 단계, 이미지 1/2 Numark TT1600 Tone Arm Replacement: 7 단계, 이미지 2/2
    • Remove the two remaining screws connecting the tone arm to the device.
  8. Numark TT1600 Tone Arm Replacement: 8 단계, 이미지 1/1
    • Flip the turntable back over to the top side.
    • Remove the counter weight located at the back of the tone arm.
  9. Numark TT1600 Tone Arm Replacement: 9 단계, 이미지 1/3 Numark TT1600 Tone Arm Replacement: 9 단계, 이미지 2/3 Numark TT1600 Tone Arm Replacement: 9 단계, 이미지 3/3
    • Push out the pin keeping the tone arm in place using a Phillips #00 screwdriver.
    • Once you have pushed the pin out with the screwdriver, pull the rest of it out using your hand.
  10. Numark TT1600 Tone Arm Replacement: 10 단계, 이미지 1/3 Numark TT1600 Tone Arm Replacement: 10 단계, 이미지 2/3 Numark TT1600 Tone Arm Replacement: 10 단계, 이미지 3/3
    • Pick up the tone arm and point the back end of it towards its base.
    • Push the back end of the tone arm into the hole.
    • Flip the turntable over and pull the tone arm all the way through the hole.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Nikolai
회원 가입일: 10/12/11
254 평판
안내서 5개 작성하였습니다
Cal Poly, Team 17-14, Regan Fall 2011 Cal Poly, Team 17-14, Regan Fall 2011 회원
CPSU-REGAN-F11S17G14
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 24
전체 시간: 8,302
