이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the clip located on the backside of the audio jack housing by gently pulling it out.
The clip is located right underneath the audio jacks.
Remove the screw that connects the black wire of the tone arm to the base of the audio jack housing.
Gently pull the wire that you just unscrewed to release it from the clip.
Flip the turntable back over to the top side.
Remove the counter weight located at the back of the tone arm.
Push out the pin keeping the tone arm in place using a Phillips #00 screwdriver.
Once you have pushed the pin out with the screwdriver, pull the rest of it out using your hand.
Pick up the tone arm and point the back end of it towards its base.
Push the back end of the tone arm into the hole.
Flip the turntable over and pull the tone arm all the way through the hole.
다른 3명이 해당 안내서를 완성하였습니다.
