주요 콘텐츠로 건너뛰기
Numpad with Keyboard Removal
단지 전제 조건
이 가이드는 전제 조건 전용 가이드입니다! 이 가이드는 다른 절차의 일부이며 단독으로 사용할 수 없습니다.
  1. Numpad with Keyboard Removal, Before you begin: 1 단계, 이미지 2개 중 1개 Numpad with Keyboard Removal, Before you begin: 1 단계, 이미지 2개 중 2개
    • Unplug all cables and fully shut down your laptop.
    • If your repair requires a spudger, a T5 Torx, or a Phillips screwdriver, you can use the included Framework screwdriver. Whichever works best for you!
  2. Numpad with Keyboard Removal, Remove the touchpad spacers: 2 단계, 이미지 3개 중 1개 Numpad with Keyboard Removal, Remove the touchpad spacers: 2 단계, 이미지 3개 중 2개 Numpad with Keyboard Removal, Remove the touchpad spacers: 2 단계, 이미지 3개 중 3개
    • Use your fingers to slide the touchpad spacer toward the bottom edge of the laptop and unclip it.
    • If you're having trouble, check if the corresponding Input Module latch is properly unlocked.
    • Lift the touchpad spacer off the laptop and remove it.
  3. Numpad with Keyboard Removal: 3 단계, 이미지 1개 중 1개
    • Repeat the same procedure for the other touchpad spacer.
  4. Numpad with Keyboard Removal, Remove the touchpad: 4 단계, 이미지 3개 중 1개 Numpad with Keyboard Removal, Remove the touchpad: 4 단계, 이미지 3개 중 2개 Numpad with Keyboard Removal, Remove the touchpad: 4 단계, 이미지 3개 중 3개
    • Use your fingers to slide the touchpad toward the bottom edge of the laptop and disconnect it.
    • If you're having trouble, check if the Input Module latches are properly unlocked.
    • Lift the touchpad and remove it.
    • During reassembly, perform the following:
    • Place the touchpad flat on its cutout so its clips are properly aligned.
    • Press the touchpad down and slide it into place so it lines up evenly with the bottom edge of the laptop.
  5. Numpad with Keyboard Removal, Remove the keyboard: 5 단계, 이미지 3개 중 1개 Numpad with Keyboard Removal, Remove the keyboard: 5 단계, 이미지 3개 중 2개 Numpad with Keyboard Removal, Remove the keyboard: 5 단계, 이미지 3개 중 3개
    • The keyboard is held in place with strong magnets. Apply gradually increasing force to avoid having the keyboard violently eject.
    • Grip the two pull tabs along the bottom of the keyboard.
    • Lift the pull tabs until the keyboard magnets release.
    • Remove the keyboard.
    • During reassembly, make sure the keyboard is seated properly on its alignment pegs and sits evenly with the edges of the laptop.
  6. Numpad with Keyboard Removal, Remove the numpad: 6 단계, 이미지 3개 중 1개 Numpad with Keyboard Removal, Remove the numpad: 6 단계, 이미지 3개 중 2개 Numpad with Keyboard Removal, Remove the numpad: 6 단계, 이미지 3개 중 3개
    • The numpad is held in place with strong magnets. Apply gradually increasing force to avoid having the numpad violently eject.
    • Grip the pull tab at the bottom of the numpad.
    • Lift the pull tab until the numpad magnets release.
    • Remove the numpad.
    • During reassembly, make sure the numpad is seated properly on its alignment pegs and sits flush with the edges of the laptop.
결론
Alex Diaz-Kokaisl
회원 가입일: 01/16/22
215,931 평판
안내서 1,046개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,829개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 37
