주요 콘텐츠로 건너뛰기
Nuphy Air75 Keyboard Switch Replacement
필요한 것
  1. Nuphy Air75 Keyboard Switch Replacement, Keyboard Switch: 1 단계, 이미지 2개 중 1개 Nuphy Air75 Keyboard Switch Replacement, Keyboard Switch: 1 단계, 이미지 2개 중 2개
    • Place your keyboard on a clean, well-lit surface.
    • Slide the keyboard power switch to the "off" position.
  2. Nuphy Air75 Keyboard Switch Replacement: 2 단계, 이미지 3개 중 1개 Nuphy Air75 Keyboard Switch Replacement: 2 단계, 이미지 3개 중 2개 Nuphy Air75 Keyboard Switch Replacement: 2 단계, 이미지 3개 중 3개
    • Find the wire side of the keycap puller. Slide each wire around opposite sides of the key you are replacing.
    • Pull gently until the key cap comes off.
    • Pull the keycap straight up. This will prevent damage to adjacent keycaps.
  3. Nuphy Air75 Keyboard Switch Replacement: 3 단계, 이미지 3개 중 1개 Nuphy Air75 Keyboard Switch Replacement: 3 단계, 이미지 3개 중 2개 Nuphy Air75 Keyboard Switch Replacement: 3 단계, 이미지 3개 중 3개
    • Use the other side of the switch puller, with two large metal prongs. Fit the prongs onto either side of the switch.
    • Pull the switch out using a side-to-side motion. When one side of the switch lifts up with an audible click, gently lift the other side to fully remove the switch.
    • Do not rock side-to-side into other keys. You can damage adjacent keycaps and the keyboard itself.
  4. Nuphy Air75 Keyboard Switch Replacement: 4 단계, 이미지 2개 중 1개 Nuphy Air75 Keyboard Switch Replacement: 4 단계, 이미지 2개 중 2개
    • Orient the replacement switch so that the colored, circular module is facing up.
    • Gently press down until you hear an audible click.
    • Place the keycap over the newly installed switch and gently press down.
  5. Nuphy Air75 Keyboard Switch Replacement: 5 단계, 이미지 2개 중 1개 Nuphy Air75 Keyboard Switch Replacement: 5 단계, 이미지 2개 중 2개
    • Turn the power switch to the "wired" or "wireless" position depending on your setup.
    • Test your keyboard and new key switch.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Brad
회원 가입일: 01/16/24
145 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 49
지난 30일: 181
전체 시간: 2,572
