주요 콘텐츠로 건너뛰기
Nutri Ninja BL450 Cooling Vent Replacement
필요한 것
  1. Nutri Ninja BL450 Cooling Vent Replacement, Small Rubber Wheel: 1 단계, 이미지 1/1
    • Remove the cup from the blender base.
  2. Nutri Ninja BL450 Cooling Vent Replacement: 2 단계, 이미지 1/2 Nutri Ninja BL450 Cooling Vent Replacement: 2 단계, 이미지 2/2
    • Turn the blender over and unscrew the three 14 mm screws holding the slotted base in place. These are Torx Security bits (TR9) on some units.
  3. Nutri Ninja BL450 Cooling Vent Replacement: 3 단계, 이미지 1/3 Nutri Ninja BL450 Cooling Vent Replacement: 3 단계, 이미지 2/3 Nutri Ninja BL450 Cooling Vent Replacement: 3 단계, 이미지 3/3
    • Using a the standard Phillips head screwdriver bit, remove the slotted black plastic covering and then unscrew the one 11mm screw holding the power cord in place.
    • Unscrew the four 14 mm screws that are in the deep slots. This will release the motor from the base.
  4. Nutri Ninja BL450 Cooling Vent Replacement: 4 단계, 이미지 1/3 Nutri Ninja BL450 Cooling Vent Replacement: 4 단계, 이미지 2/3 Nutri Ninja BL450 Cooling Vent Replacement: 4 단계, 이미지 3/3
    • CAUTION: the silver blade attached to the motor is very sharp. Use a towel or thick cloth to protect your hands for the next step.
    • Using a towel, hold the silver fan still. Twist the small black rubber wheel that is attached to the top of the blender base to the right. This will remove the wheel for replacement.
  5. Nutri Ninja BL450 Cooling Vent Replacement, Cooling Vent: 5 단계, 이미지 1/2 Nutri Ninja BL450 Cooling Vent Replacement, Cooling Vent: 5 단계, 이미지 2/2
    • Slide the cooling vent out from the silver plastic part of the blender base and replace it.
결론
Morgan Blauth
회원 가입일: 02/24/16
780 평판
안내서 5개 작성하였습니다
USF Tampa, Team 1-5, Leahy Spring 2016 USF Tampa, Team 1-5, Leahy Spring 2016 회원
USFT-LEAHY-S16S1G5
2 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 15
전체 시간: 1,413
