주요 콘텐츠로 건너뛰기
Nutri Ninja Ninja Blender Duo BL641 Blade Replacement
필요한 것
  1. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement, Blade: 1 단계, 이미지 1/2 Nutri Ninja Ninja Blender Duo BL641 Blade Replacement, Blade: 1 단계, 이미지 2/2
    • Make sure blender is turned off.
    • Lift open the lid of blender by pressing the "Release" button and move to the side
  2. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: 2 단계, 이미지 1/2 Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: 2 단계, 이미지 2/2
    • Carefully Grab the top of the blade and pull upward with medium force.
    • The blade should slide out easily.
    • Do not touch the blades! Even when dull they can still cut you.
  3. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: 3 단계, 이미지 1/2 Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: 3 단계, 이미지 2/2
    • Carefully pick up the new blade and match the bottom star shaped opening to the star shaped protrusion from the blender.
  4. Nutri Ninja Ninja Blender Duo BL641 Blade Replacement: 4 단계, 이미지 1/1
    • Slowly connect the two star shapes together and push down until it reaches the bottom.
결론
Now your blender can resume blending to perfection.
Charlotte
회원 가입일: 09/26/17
101 평판
안내서 1개 작성함
Cal Poly, Team S7-G1, Banghart Fall 2017 Cal Poly, Team S7-G1, Banghart Fall 2017 회원
CPSU-BANGHART-F17S7G1
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 15
30일 전: 53
전체 시간: 3,142
