주요 콘텐츠로 건너뛰기
Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement
필요한 것
  1. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement, Nutri Ninja Ninja Blender Duo BL641 Body Disassembly: 1 단계, 이미지 1/1
    • Turn blender upside down
  2. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 2 단계, 이미지 1/2 Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 2 단계, 이미지 2/2
    • Remove these six screws (0.5 inch 5 gauge phillip's head)
    • Note: 2 of the screws will be star shaped circled in blue
    • Lift the bottom panel off
  3. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 3 단계, 이미지 1/1
    • Unscrew and remove these six phillip's screws. (0.5 inch 5 gauge phillips)
    • Note: The screws circled in blue are 1/8" longer and have a slightly different top than the rest. These are the only two screws that are different than the rest.
  4. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 4 단계, 이미지 1/3 Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 4 단계, 이미지 2/3 Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 4 단계, 이미지 3/3
    • Insert pry tool in between the two plastic pieces to separate them
    • Move pry tool back and forth from right to left until the two pieces begin to separate as shown.
    • Pry the two pieces apart with your hands as shown in the picture to finish separating the pieces.
  5. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 5 단계, 이미지 1/1
    • This completes the disassembly of the main body of the blender so you can continue to perform replacements on the internal parts.
  6. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement, Motherboard: 6 단계, 이미지 1/1
    • Remove the phillip's screws from the motherboard.
  7. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 7 단계, 이미지 1/1
    • Flip the motherboard over.
  8. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 8 단계, 이미지 1/1
    • Remove any plugs from the motherboard.
  9. Nutri Ninja Ninja Blender Duo BL641 Motherboard Replacement: 9 단계, 이미지 1/1
    • Desolder wires and cords. Replace old motherboard with new one, and resolder wires and cords.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Will Jones
회원 가입일: 09/26/17
155 평판
안내서 1개 작성함
Cal Poly, Team S7-G1, Banghart Fall 2017 Cal Poly, Team S7-G1, Banghart Fall 2017 회원
CPSU-BANGHART-F17S7G1
5 회원들
안내서 6개 작성하였습니다
댓글 한 개
Hello Will - thank you for that lesson. I am from Canada, going to CUBA and my Cuban friend needs the motherboard for a similar blender (BL 770-2.) Where do I buy one? Thanks.
Judith Falardeau - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 38
전체 시간: 1,242
