주요 콘텐츠로 건너뛰기
Nutri Ninja Ninja Blender Duo BL641 Power Cord Replacement
필요한 것
  1. Nutri Ninja Ninja Blender Duo BL641 Power Cord Replacement, Power Cord: 1 단계, 이미지 1/2 Nutri Ninja Ninja Blender Duo BL641 Power Cord Replacement, Power Cord: 1 단계, 이미지 2/2
    • Unscrew the screws from the base of the blender (These should be 5 gauge phillips head screws).
    • 2 of the screws will be star shaped rather than phillips head.
    • Remove the base plate.
  2. Nutri Ninja Ninja Blender Duo BL641 Power Cord Replacement: 2 단계, 이미지 1/2 Nutri Ninja Ninja Blender Duo BL641 Power Cord Replacement: 2 단계, 이미지 2/2
    • Identify the red and black wires topped with white-clear caps.
    • Use pliers to squeeze the flattened part of both caps.
    • The black and red wires attached to the power cord should be loose and ready to pull out.
  3. Nutri Ninja Ninja Blender Duo BL641 Power Cord Replacement: 3 단계, 이미지 1/1
    • Replace the cord by slipping the new cord's black and red wires into the caps.
    • Pinch the middle of the cap back to the flattened position using the pliers.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Allie Decker
회원 가입일: 09/26/17
125 평판
안내서 1개 작성함
Cal Poly, Team S7-G1, Banghart Fall 2017 Cal Poly, Team S7-G1, Banghart Fall 2017 회원
CPSU-BANGHART-F17S7G1
5 회원들
안내서 6개 작성하였습니다
댓글 2개
Como puedo extraer la parte donde sienta el vaso de mi licuadora ninja ct641
Memorex com - 답글
Como puedo extraer la base donde asienta el vaso de licuadora ninja ct641
Memorex com - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 44
전체 시간: 3,734
