주요 콘텐츠로 건너뛰기
Nutribullet Rx #NB-301 Drive Socket Replacement
필요한 것
  1. Nutribullet Rx #NB-301 Drive Socket Replacement, Drive Socket: 1 단계, 이미지 1/3 Nutribullet Rx #NB-301 Drive Socket Replacement, Drive Socket: 1 단계, 이미지 2/3 Nutribullet Rx #NB-301 Drive Socket Replacement, Drive Socket: 1 단계, 이미지 3/3
    • Make sure to unplug the device before you start the repair.
    • Flip the blender over so the bottom is facing up.
    • Use a Phillips #2 screwdriver to remove the four 10 mm screws from the base of the blender.
    • Remove the base cover from the blender.
  2. Nutribullet Rx #NB-301 Drive Socket Replacement: 2 단계, 이미지 1/2 Nutribullet Rx #NB-301 Drive Socket Replacement: 2 단계, 이미지 2/2
    • Clamp down on the nut above the socket with the needle nose pliers so it stays in place for the next step.
  3. Nutribullet Rx #NB-301 Drive Socket Replacement: 3 단계, 이미지 1/3 Nutribullet Rx #NB-301 Drive Socket Replacement: 3 단계, 이미지 2/3 Nutribullet Rx #NB-301 Drive Socket Replacement: 3 단계, 이미지 3/3
    • Lay the blender on its side and hold the drive socket with the needle nose pliers to keep in from turning so you can remove the screw.
    • Use a Phillips #2 screwdriver to remove the screw securing the drive socket.
  4. Nutribullet Rx #NB-301 Drive Socket Replacement: 4 단계, 이미지 1/3 Nutribullet Rx #NB-301 Drive Socket Replacement: 4 단계, 이미지 2/3 Nutribullet Rx #NB-301 Drive Socket Replacement: 4 단계, 이미지 3/3
    • Remove the drive socket from the motor.
  5. Nutribullet Rx #NB-301 Drive Socket Replacement: 5 단계, 이미지 1/3 Nutribullet Rx #NB-301 Drive Socket Replacement: 5 단계, 이미지 2/3 Nutribullet Rx #NB-301 Drive Socket Replacement: 5 단계, 이미지 3/3
    • Remove all dust and residue from the area before you replace your new drive socket.
  6. Nutribullet Rx #NB-301 Drive Socket Replacement: 6 단계, 이미지 1/3 Nutribullet Rx #NB-301 Drive Socket Replacement: 6 단계, 이미지 2/3 Nutribullet Rx #NB-301 Drive Socket Replacement: 6 단계, 이미지 3/3
    • Use a Phillips #2 screwdriver to secure the drive socket to the motor.
  7. Nutribullet Rx #NB-301 Drive Socket Replacement: 7 단계, 이미지 1/2 Nutribullet Rx #NB-301 Drive Socket Replacement: 7 단계, 이미지 2/2
    • Place the bottom cover back on the blender.
    • Use the Phillips #2 screwdriver to replace the four 10 mm screws on the back cover back.
결론
Martin G
회원 가입일: 03/05/24
145 평판
안내서 1개 작성함
CSU Los Angeles, Team 7-3, Grodsky Spring 2024 CSU Los Angeles, Team 7-3, Grodsky Spring 2024 회원
CSULA-GRODSKY-S24S7G3
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 12
30일 전: 55
전체 시간: 80
